gc wrx fault code 35
Hi people i have a 1994 gc wrx and i have just replaced the motor with a twin turbo long block.
I have changed all of the sensors, loom manifolds etc over and got it running sweet but now the cel has come on. I have had the fault code 35 come up and my question is what is code 35?
on occasion it feels like it is hitting boost cut btu its only running 6psi. it lets out a dirty great backfire and dies for a couple of seconds.
Any help would be very much appreciated :)
i ran the codes thru google and got the following....Code 35:
Turbo Charger Bypass Valve Control Circuit High
and then (different website)
This Relates to Circuit High for Super/Turbo Charger Bypass Valve Control..
Only things i could think of was vacuum lines to boost controller wrong or blocked bypass valve or jammed??...could well be wrong tho!
found it was all plugged in and power getting to it, bottom hose of the solonoid going to resinator box was not hooked up, i connected this, went for a drive with the green and black plugs connected and the fault code is still coming up.
It is now running around 10psi boost instead of 6psi, and it only hits fuel cut and back fires in 3rd gear.
The only non fact mods are bosch fuel pump, external wastegate, k&n panel filter, exhaust and bov
Any ideas?
