Turbo for 02 RSK B4
Enervated
  • 3 months later...
with my B4 2002, I have just had a turbo upgrade with the primary to a TD04 with rage pipes and full exhast and it is real quick now.Masssive change in power. No reprogramming has been done yet tho so only running 10psi boost but still runs great. Sounds awesome to. Cost were $2000 . Highly recommend .
What did you have to modify to get the TD04 in? Sounds like its worth having a look into ;)
 Chosimba']
What did you have to modify to get the TD04 in Sounds like its worth having a look into ;)
You can use the existing turbine housings but they need to be machined to allow for the upgraded turbo. The TD04 is a straight bolt on to the housing with no mods. Two TD04 can be installed but the main gain is with the primary as it is the main turbo that is always working. Work shop in East Tamaki called Innovate did my and the owner has a B4 twin TD04 set with 14psi boost which is why I went with it.
For optimal upgrade the secondary turbine TD04 should be installed but not necessary .
 Enervated said:
Why only 10psi?? I have factory setup running 14psi :S And thanks for the tip.. but I've decided to save up and buy an evo. lol :D
I'm running 10psi because that is what my car came standard as, need to get it sorted soon.
Sounds wicked man.
So is it quite a noticeable difference? When does the primary spool up now?
Wouldn't be able to flick some pictures up of your beast would ya
Cant work out how to attach photos.
Yeah there is quite a bit of difference as the original turbo is just to small , I really need to get the boost up.
