removing cam gears
raymong
how do i remove cam gears without using the subaru tool to lock the camgear..stuck...
i have v7 wrx
its allen/hex key bolts...
one cam gear has holes the other 3 has a round cam gear inside the cam gear it self...
ley me know thanks
0220151350
the tool is cheap from bnt, only about $30 its the same as a BMW service tool, i've got one here if your in welli.
If you've got strong enough hands use an old cam belt to hold the pulley still,
or if your really rough as a last resort just crack the bolts with the cambelt still in place, but dont do it this way if your reusing the tensioner.
note: be very careful with the plastic pullleys as they chip easily and dont overtighten the screws in the plates on the intake cams ifits an sti, they are mounted on a rubber seal (that keeps the oil where its ment to be for the AVCS)
Does the tool just lock the inlet and exhaust togeather by sliding in between the cam gears? any idea if it will work with quad avcs?
i broke one of the camgears :-[ anyone got a spare one its passenger side inlet one...
i tried the cambelt method and only got one undone...they are tight as!!!
the other cam just slipped the cam
so u think it has to be the pulley from bnt..is there bnt in rotorua?
post up a pic, are you sure thats the right one, passenger side inlets are all steel aren't they?
I think i've got a spare set off a v5, 99% they are the same on a non sti v7
Great example of getting the right tool for the job though ;D
