Where to mount mechanical oil temp sender?
Hey
ive tried searching but i havent found anything to help.
Ive got a mechanical oil temp guage and sender, is there any location that people normally use?
The car is an early turbo forester,
any help would be much appreciated
If your Forester is a 1997/98 then it will have the same engine as a V3/V4 WRX so any info you find on a v3/v4 will be transferable to a Forester.
Your engine should therefore be an EJ20G, have a td04 etc etc
If it is a late 1998-2001 then it will be a EJ205(?) same as a V5/V6 WRX and info will be transferable from these models.
Hope this helps
