fuel pump fuse
97 gtb keeps blowing fuel pump fuses usually under load or high revs is this a sign the fuel pump is dicky or its shorting out some where along the line?
measure the current flow thru the pump circuit
usually around 8 amps at prime and should be around 4-5amps running
if you have 6 amps or more at idle them pump is FUBAR
