earthing points on wrx
raymong
theres one that goes to the gear box. Has it had a clutch? someone probably missed undoing it and when the gearbox was half hanging off and cut it.
 Stoffa said:
you could be onto something with the earths, check the ones on your inlet manifold from what I understand one of those is one of the ecu earths
Yeah esp if you've powdercoated the manifold, you'll want to relocate that earth to the engine block and use a star locking washer.
 caged']
[quote name='raymong said:
can someone try and see if car will run poo's if the earth is off? lol
No it wont from just that earth.
OH yes they can, if the gearbox isnt earthed properly then the neutral switch wont work properly
This will cause havoc with drivability
 Ichi Ban']
They can, but not if all the other earths are fine. It will just earth through the engine. But you know that :P
