Heater Control Unit Fault
Guest steve.c
Guest steve.c
I have an intermittent fault with the Heater Control Unit in a 1996 Legacy GT. It will display -25 Deg C and blow hot air regardless of the mode or if A/C is on or off. Any ideas on what to replace the Heater Control Unit or external Temperature Sensor would be appreciated.
Out temp sensor mounted in front of radiator
Sound more like sensor / or wiring going open circuit rather than control module issue
Guest steve.c
Cheers, have plugged in a mates control unit and it still displayed -25. eventually it started to to read a normal outside temp so unplugged the outside temp sensor and it dropped to -25 straight away. looks to be a faulty sensor.
