Legacy B4 central locking (door actuator sensor) issue
Hi all,
Bought a '99 Legacy Sedan (non-turbo/non bilstein) about a year ago, and a few months after purchase the central locking started acting up, in a way that when i unlocked the car (via remote from Mongoose M80G alarm) it would lock itself within 1sec again.
Cut a long story short i found the issue was with the drivers side door actuator, in that the sensors in it had worn, whenever i manually key locked the passenger door there was no issue but drivers side would lock it straight away again. Therefore i managed to replace this & fixed the issue.
However, 8 months down the track it has now happened again. Is this a normal subaru issue? Any ideas on what could be causing this?
The only lead I have is that I self-installed dynamat sound deadening into the front two doors pretty early on, and am thinking this could be rubbing against the rods that are up against it leading to the locking unit, meaning it eventually wears down the motor/sensors? Pulled apart the old one last time and couldnt find any cogs or anything that looked worn however...
Any ideas/suggestions greatly appreciated! Quoted something like $1000 to replace... however have done it myself with a $25 replacement from trademe... just a bitch to get in & out!
Cheers!
  • 3 weeks later...
 BEB4 said:
Any ideas on this guys? or possibly anyone who is wrecking a be5 legacy or similar.....
cheers
Never had any issue with this on either a B4 or GT wagon.
Have you checked the troubleshooting guide in the Subaru Service Manual for the BE5 RSK?
If you have lock rods fouling door frame, fix this first
Not uncommon at all for locking master unit to fail (drivers door lock/catch assembly)
I see that you replaced with 2nd hand, this is not great practise and often results in fault re-occuring
The price of 1k seems "out there", can you buy the part by itself and fit it yourself?
Thanks guys, appreciate the replies. Just want to make sure I do it properly this time as didn't expect this to reoccur so quickly.
Will probably end up taking out sections of the dynamat just in case. Will also look into getting a new assembly, and have no problems replacing it myself - just need to find somewhere I can get it @ a reasonable price.
Cheers again
