Gauge install on popup dash
wrx_lou
Ok so im trying to track down a 22b style cowling (also in the 97-00 V limited and ive seen them in some Foz's) but in the mean time I needed to install my gauges somewhere. The popup dash compartment was the obvious choice, but i didnt like the look of the ugly bases being in full view so i decided to sacrifice the lid. heres a couple of pics;
Basicaly to conseal the bases, I removed the lid and undid all the screws which splits it into two pieces. I then used a dremel to cut 3 holes large enough for the gauge mounts to pass through but not actual bases. I mounted the gauges to the top part of the lid with double sided tape on the top of the bases to the bottem of the top piece of the lid. (Lol i just made that real confusing eh?) After all that i screw the 2 peices back togather and used a 12mm flat drill bit to make the holes for the wire. I drilled them as close as possible to the gauges so there wasnt too much wire visible.
I can put up some more photo's if you wanna see a bit more detail.
