Help, Central Locking And Windows Haunted...
Phewsion
Hey all
So I just installed my speakers in to the drivers side door and things started going haywire
Firstly: The little switch by door handle that you use to lock/unlock all 4 doors: When the car ign is in ACC or engine running The doors won't stay locked, flick switch locks then auto unlocks (Locks properly when key is out of Ignition)
Secondly: Drivers side door "Auto" Function doesn't work anymore, Holding it down lowers window fine, Pulling back the window goes up then stops, gotta repeat the process to shut window i.e Pull up > Window Stops > Pull Up Again > Window Stops, From complete open I gotta do this 4 times to shut the window
I have checked the plugs/wires to make sure I didn't accidentally cut a wire or put the plug back wrong, These are fine.
Could a Fuse cause this?
I gots a ghost in the machine! :(
Edit: 2003 Subaru Legacy GTB D:
sounds like you need a window reset - dam its been years since i last did one, will have a scratch around my paperwork
As for ya door locks I think you'll find thats how they are if the door is open
