94 impreza engine swap
Hello all. My 15 year old son inherited a 94 Impreza from his uncle. Unfortunately, the engine was blown. We purchased a used one from a wrecker and swapped it out. Everything went well until we tried to plug in the two big terminals in at the back of the engine. One of the terminals was the wrong shape. We took the old wire harness off of the bad engine and installed it on the new engine. Everything seemed to plug right in with no "leftovers". The engine won't fire at all. I tried a little starting fluid to see if it was a fuel problem. It backfired as if the timing is off, but I understand that the timing is controlled by the computer and is not adjustable. I swapped the cam position sensor, the crank position sensor and the coil pack from the old engine. No change. This is the EJ 18 engine. I have seen people referring to the "fuel MAP". I don't know what this means. Does anyone have any ideas? Any comments or ideas will be appreciated.
