WRX clicking/rattleing random noise. help!
hey guys i have a v3 sti sedan and its sort of making a noise when i come to a stop its not overly loud i have to listen quite hard to hear it but when i stop then put the clutch in it makes a kind of clicking noise and when i dont have the stereo on i can hear a slight knocking when im driving along ive stopped and given the car revs when its making the noise an it is not there am farily confident its not the motor. its almost a thrust bearing but doing the opposite it only makes the noise when the clutch is in not when it is out.
Please help!! :)
unsure of k'z on clutch, or engine as its had a rebuild.. the bodys done 200,000kz but duno if the clutch has been replaced to be quite honest.
Try this, when you start it from cold (from sitting overnite), if its the clutch throw out bearing it's usually noisier from cold when you push the pedal in.Other than that have it checked out by a specialist subaru reparier.
