1991 Legacy GT > WRX Conversion
stiwagon
Hey Guys,
Iv got a customer that wants to do a WRX Conversion on his 1991 Legacy GT Wagon. I have tried searching the web but have been unable to find a build thread or anything that tell exactly what needs changing.
He wants to put a 1996 WRX Engine & Gearbox in it. I know it will physicly bolt in and the axles should all fit. But theres a few things im unsure of..
The wiring loom will obviously need changing but to what extent? Changing the whole loom means the dash wont work so can you just change the ecu > engine part?
Also I had read that the front subframe needs changing to clear the exhaust, is this true?
And things like the main drive shaft etc, will they still fit?
If anybody has any info on this conversion id love to know or any links to other threads. Just wanting to know everything thats involved in a conversion before he goes ahead.
Thanks
It depends on what year the WRX stuff is?
Its a pretty straightforward swap as the early single turbo Legacy's shared most of their engine/driveline with the early WRX's. If the WRX ECU you have is a 3-plug, it becomes a bit harder. The mechanical fitment of it is still all straightforward but you then need to use three of the four original ECU plugs in the Legacy loom, as well as re-pin them to suit the 3-pin layout. The "single turbo Legacy" thread has the various pinout diagrams etc to help.
http://www.clubsub.org.nz/forum/index.php/topic,74.0.html
You cannot change just the engine to ECU part of the loom as it is integrated with the entire body loom of the car. Is easy enough to swap the pins around at the plug and work it out that way though.
