Idle sensor issues
Hi all, I'm new on here but have own a 97 wrx which i plan to use as a track car and something to have a bit of fun with. When i bought this car i was told it was a sti but apparently its not it only has a later model sit engine in it.
The problem is that the newer model engine's idle sensor is different to the 97 sensor. At the moment the new air flow sensor is not connected because the plugs are different and the old sensor is bolted to the intake manifold and connected but obviously not doing anything resulting in check engine lights and a very rough idle.
Is there a way to get around this without replacing the manifold which I've been told has a different bolting pattern. Am i able to rewire the new sensor using the old wires or is it more complicated than this?
Also when they replaced the engine would they of replaced the ECU or would the old ECU still be able to "talk" to the new engine?
Any help would be greatly appreciated.
Thanks
