need alignment help asap
picked up a bc5 rs today, drove it 230kms home and a tyre blew out...
the inside shoulder had gone right through the belt.
had a look at the left and its delaminated and through the belt too..
i dont wanna chuck new tyres on and drive it into town till i can get a semi aligned setting on it..
does anyone know what the correct distance is from the centre of the tie rod ends?
or should i just take the front wheel off and get them parallel? ???
I run my wrx with zero toe, i.e parallel, if your clever you can use a builders square and string line, make a square rectangle around your car then measure the distance from the front of your rim to the string and the rear of the rim to the string, you just need to make the distances equal. If the rectangle isn't square your wasting your time.
if your only driving 10-20 kms you wont chew out your new tyres though
dont have a square or string line.
shes pulling hard to the left,like going round a round about by itself....
this is my 3rd early legacy..
been round here awhile but my account seems to be buried due to not being active i guess..
ill try to get it parallel tomorrow and see what happens..
cheers
