V2 Boost problem...
hey guys,
My wrx normally runs a solid 10 pounds, but as of yesterday it has started running only 5-7pounds... this has happened once before and i found a loose hose clamp... this time all the hoses and clamps seem to be fine though? I was thinking it might be the standard recirc valve leaking? as it doesnt really make the same noise that it used to.. Could anyone help me out with ideas on what could be causing this and how i could fix it? I want my boost back so it would be greatly appreciated.... thanks.
bro try resetting ur computer - unpower battery for a while (i usually leave for an hour or 2 to be on the safe side but can be as little as 20 mins to half)
then see if problem presists
check for error codes at that point and hopefully that should give an idea whet may be the issue
all the best!
