Central Locking FAIL 1995 BG5
My 1995 Legacy Grandwagon Central Locking failed yesterday.
FYI - I have an AVS alarm system installed.
It has the following symptoms...
1. My AVS Alarm remote will only lock and unlock the Drivers door. It used to work all doors including the rear hatch.
2. When inserting the key to unlock/lock the doors, again only the drivers door will unlock/lock where once all doors did.
3. The PIN entry using the drivers door handle no longer works. When raising the handle to enter the code, it used to \'beep\'... it no longer beeps.
I have...
Checked the fuse and this is fine.
I can not hear clicks (common i believe) where the control box is located... behind the glovebox i think.
If anyone could point me in the right direction with a remedy, it would be GREATLY appreciated!
