Lamco gague install
I just got my lamco gauges , Boost , Oil Temp , Oil Pressure . Have got power to all of them via my dash clock but need to plug in the pressure sensor and temp sensor . To install the temp sensor you need to remove the alternator. It says to loosen the alternator belt but im unsure weather i just tighten it again afterwards or is it at a special tension ?
 Stoffa said:
temp sensor is usually in the sump plug on the lamco\'s, oil pressure goes under the altenator, and no its not at a special tension setting, dont over tighten it, but if its too loose it\'ll squeel.
hi my lamco oil pressure gauge is not working, was thinking about finding out whats wrong, how exactly is it connected?
