Factory Subaru McIntosh Head Unit error 06
Hi Guys,
just got a new lancaster 99, and the unit is giving me error 06 on purchased and burnt cds.
Should I look at taking the unit out and opening/cleaning it. Or just replace the unit with something more useful in todays world.
I saw Scoobys post about bypassing the amp by snipping here and there, but on my travels I also found this which is a wiring diagram for a RCA/DIN converter to use the amp still, which souldnt be toooooo hard to do if I take the time.
http://www.subaruoutback.org/forums/printthread.php?s=&threadid=4426
If I made the converter would that mean I could literally just plug any HU in and RCA direct to the AMP and not need to worry about rewiring anything else?
Yes, you can connect any headunit with line level (aka RCA) outputs to the McIntosh amp using those connections.
I had a McIntosh doing the same thing (and error 03 as well). Carefully wiping the lens with a cotton bud soaked in isopropyl alcohol fixed that.
