Manual Conversion Wiring
I did a manual conversion a while ago, and have recently changed to a manual ecu. With the manual ecu the car now has a permanent CEL which I have traced to doing the manual conversion.
I have done some wiring but obviously some thing is not right, and was hoping that some one could do a write up on what to do, so I can see where I went wrong and to help other people wanting to do this.
Thanks
more info on the car may be helpful for people, or more info on the ecu u used and the one that was in it.
ive been lead to beleave that some subaru ecu's all you need to do is snip a certian earth wire to let it know its manual.
-smurff
The car is a 98 GF8 wrx and i have done an STI ECU conversion. I am now getting the CEL code 24, idle control valve.
Now i had been having problems with my idle, but when i disconnected the auto control computer the idle came right. However the CEL stayed on, my car runs right but has the CEL on and runs in safe mode :(.
The wiring that i have done is:
shorted out wires 9 and 10 on the auto plug
connected wires 11 and 12 on the auto plug to 2 and 4 on the manual plug
connected wires 1 and 4 on the auto plug to 1 and 3 on the manual plug
put a 5v feed into the neutral
Now i have heard that Subaru ECUs have an auto/manual identifier, but all the wiring diagrams for v3/4 that i have found have no mention of one.
