VF38 & VF40
fbssub1
Have ordered a VF38 rebuild kit from Japan, now the kit says it does VF40 aswell, are the cores the same as I can get a new core for the fraction of the cost of a replacement turbo, the only thing is I only see VF40 core available, will it fit into the VF38 housings.
Cheers Brian
YES
http://legacygt.com/forums/showthread.php/vf38-versus-vf40-mid-47938.html?s=bf75321a2e0b54bb952efc8ab8548eb9&
"I have both in my garage and I\'ve taken them apart. The VF38 has a twinscroll exhaust housing and a slightly different compressor housing in comparison to the VF40, and it has a titanium turbine wheel as well. As for dimensions (inducer-exducer) for their compressors and turbine wheels, they are exactly the same. So you could go ahead and use the CHRA (center housing rotating assy) "center section" with the VF40 housings and it would bolt right up no problem. Hope this helps clear this matter for you."
