Rough Idle
I have just changed the head gasket on my WRX. Its running but at a very rough idle then stalls. Its not the timing belt this all lines up. When I start the car it runs fine for the first 10 seconds then settles into a rough idle. I have no engine check light on. I have tried to move the idle control but to no avail. Any ideas???? Im runnning out and not sure what to do.
vacuum leaks??? have you checked over the plugs and hoses you took off??? hard to tell you what to do over the net
I was thinking a vaccum leak cant hear any air leaking though. Might just be a case of thourally inspecting the engine to see if I can find a loose pipe!
Thanks
