1989 Rs changing motor to twin turbo
If you\'re thinking of fitting the whole twin turbo system you need a) to ask yourself, "do I want to do all this work to make my car worse and more unreliable?" And b) do I like throwing money away?
If you want to fit the motor from a twin turbo legacy then it\'s an easy swap, using the original single turbo manifolds and turbo setup on the newer engine. Bonus points if you use a bg5b engine as it\'s the ej20r so you get much better heads that don\'t have hydraulic lifters. Yay.
 oldman said:
I have a 1989rs legacy has a single turbo I think it\'s on the way out does anyone know can you fit a twin turbo in it is there much to change like wiring and sensors mounts etc cheers
personally the single turbo set up i feel is better. why do you feel the need to go the a twin turbo?
 oldman said:
Thanks for the info mite stick with what\'s already in there just bought the car thought it mite be an option if the motor that\'s in it needs replacing at some stage
If the car is in good condition id spent the money and recondition the motor as those models are getting harder to come by :)
