Autogauge electric water temp gauge wiring
lunacy
Hey guys
Had an old autogauge water temp gauge lying around that i decided to chuck in the BH5 after the last engine cooked itself without warning.
I had to get a sensor, as couldnt find the old one, so just bought a 2 wire prosport one from scarles.
Ive installed the sensor inline in the upper radiator hose, and attached the sensor earth to the screw on the adaptor housing.
The gauge has 3 connection points on the back, plus a 2 wire loom.
The connection points are labelled:
I - Assume this is ignition/ +12v
G - Assume this is ground
S - Assume this is sensor.
Then a white double wire with plug, which at a guess id say is for lighting? Havnt hooked these up.
The gauge seems to work, as needle moves up to 40 degrees upon starting, and then goes to around 50 degrees once the engine is up to temp.
This seems low to me. Have i wired it wrong, or is there possibly a fault with the sensor/gauge?
Any ideas appreciated.
