13b wrx?
Zach
So I got thinking again when I came across a 13b turn key package on trademe the other day. I wont be doing it cuz I already got a path set infront of me but It's sure something I might try oneday, I don't know.
http://www.trademe.co.nz/motors/car-parts-accessories/mazda/engines/auction-764729717.htm
Would it be a pretty simple conversion? I mean the the engine is complete with loom,ecu and gearbox and should have no worries fitting into a wrx. So like custom engine and gearbox mounts, pay someone $200 to marry the box to stock driveshaft and just use stock diff. That seems simple enough,maybe a bit of axle work, I don't know if you could use stock fuel pump and lines and again im not doing this but thought Id post it cuz It looks like a cool bunny hole to fall down haha. The girl at my work has a mate up north running a v8 wrx
some of you might know him but if they can do that then a little 13b should be no worries, prob wont even need to chop firewall. Not to mention the turn key package is only 5g's so yea xD
Has been done before, subarus are relatively simple when it comes to engine swaps since they have a RWD configuration already more or less
Chicken cooker still probably less likely to die at random than an EJ, issue however is suby rear ends don't do RWD so well and become the weak point
It's as simple as any other engine swap - least the motor would fit fine
