Testing if front LSD installed
dimin
Cant for the life of me remember nor find the method to test if a front helical LSD is installed, can anyone refresh my memory ?
Just trying to figure out if my RA has a front LSD. When I put the box in, turning one axle stub caused the other to turn the opposite direction.
that would generally indicate an open diff which is pretty common. what version RA is it? only a few specific models had the helical as factory fitment. do you have a gearbox code?
just to add, the wheel spin test only works if the diff has a preload. i'm not sure that applies to a helical. which is probably why you are asking...
Edited by kamineko
Its a TY754VB1CA box, it came out of a 99 V6 Type R, its not the original box. The previous owner thought it may possibly have been a LSD equipped box as there was the option for LSD in the TY754VB1CA boxes. The TY754VB1EA in the V-limiteds I understand are the ones that definitely had an LSD.
