Rear window wiper not working but the water is working
Rzalza
Does anyone know what fuse is for the rear window wiper on a Subaru legacy gtb 2003,and if its not the fuse then why else it may not be working. The number plate lights are not working either , is there a fuse for those?
Edited by Rzalza
Unfortunately I can't tell you which fuse it is, but do the rear lights on the boot work? If everything electrical has died on the boot lid then I would check the wiring that goes between the boot and the body. It should be in a little rubber corrugated boot, top right I believe.
Over time due to it always getting bent it can eventually fail causing some of the electrics on the boot to fail depending on which wire has broken. The sprayer will still work as the motor is actually in the engine bay, not in the boot.
