AVCS wiring into non AVCS car EJ207
l2eeFer13
So whos done it?
Im putting a V7 EJ207 into my Gen 3 Legacy 1999 and the engine i got did not come with the AVCS loom. Ill be running a Link G4 ECU.
I can buy a loom from IAP but shes pretty pricey for what it is ($289USD) Link Below And i dont think it would be a plug and play with a Link
http://www.iaperformance.com/product_info.php?products_id=3217
To my understanding I can just find a set of male plugs from a wrecked bugeye and run some wires to the ECU?
It's pretty straight forward to DIY if you take your time.
Here's the engine side loom I made when I put AVCS on my GC8 (I also added idle control at the same time so that's what the extra plug is). The big DT 12 pin connector then joins to another loom I made that goes back to the ECU... I did it that way as it makes it easier/quicker to disconnect if engine needs to be removed rather than having to unplug everything individually.
If you get stuck for the sensor & solenoid plugs, give All Subaru Partsworld a call (0800 278 2278), Rosco should be able to sort you out with them.
 Tony']It's pretty straight forward to DIY if you take your time.
Cheers for that Tony. I like the idea of the connector in the bay. What ECU did you go for?
[quote name='evowrx said:
I should have spare plugs just post pics of the solenoid and sensor plugs.
That would be cool if you had them man. I go home to NZ tomorrow so will take some pics and upload them here for you
 evowrx said:
These are the ones i have so only one avcs solenoid. Hard to tell from pic but think the others suit sensors.
Cheers for that evo. Do you want those plugs or happy to sell? Ill give partsworld a call and see what they will charge for the single solenoid plug. Might just be cheaper getting all 4 from them as shipping one might not be worth it
