bc5 manuel conversion
hey i just need some one to make me a list of parts that i will need to remove off manuel non turbo 1st genration wagon that i am useing for parts on my 2nd gen turbo wagon auto to do manuel conversion
Go find a turbo gearbox. The non turbo clutch is tiny and you cant put a turbo clutch in a non turbo box. Pedals are also different. Or if you want to give it a go youll need;
Center driveshaft
Clutch pedal assembly
Clutch cable
Speed sensor (from a BG)
Brake pedal assembly with accelerator
Flywheel
Dash gauge cluster (from a BG)
Pressure plate/friction disc
New release bearing/pilot bearing
Starter motor
Gearbox and crossmember obviously
Rear diff
Big hammer in case exhaust down pipe touches the gearbox crossmember
Gear linkage
Small rubber bush that bolts underneath the shifter to hold it in place (i keep forgetting that one)
Center console and gear lever surround (from a BG)
A Million spare clutches
Thats all i can think of for now
Wait a minute.....2nd gen would be twin churbro....Definately go find a better gearbox
