What does/doesn't need to be certified?
So its time to get everything back to being legal *sigh*
I just want to know if there are any mods that I have done that don't need certification.
Mod since the last warrant are:
Coilovers
Camber bolts F & R
F & R 24mm Adj. Swaybars
F & R Endlinks
Mounting Kit for Rear Swaybar
Steering Rack Bushings
Control Arm Bushings
Anti Lift Kit
Ball Joint and Tie Rod Extenders
Rear Strut Bar with Triangle Brace
330mm Steering Wheel and Boss
17x8's
235/40's
Rolled Guards
Stripped Trunk and Carpets
What have you guys with coilovers done with the brake lines? I don't think the certifier is gonna be happy about zipties holding them in place :-X
And the car originally came with an driver's airbag so I have obviously removed that and gotten rid of the 'airbag' light on the dash with a resistor that came with the boss kit for my new wheel. Is there any way to make this legal through certification or is it fully illegal to swap out a OEM wheel with a airbag for a aftermarket one?
When you go in to get your car certified the certifier wont just look at specific modifications that you have done, he will take the entire day checking over the whole car and make notes of what needs to be certified and printed on the plate.
So it doesnt matter just take it in and theyl check everything
or about an hour..... thats all my cert took.... maybe my car looks too legit... 8)
Guest itsgotgo
i would be interested to see if these needed certification as a steering component"tie rod" mainly :)
 nztintin']
[quote name='evlRA said:
When you go in to get your car certified the certifier wont just look at specific modifications that you have done, he will b]take the entire day [/b]checking over the whole car and make notes of what needs to be certified and printed on the plate.
depends what you need to get certified
adjustable suspension required road test at 100kmph
modified engine required decibel reading and emission test
all takes time
depends on the certifier. I have a cert for coilovers and ABS removal... the certifier didn't even look at coilovers, and merely glanced at the master cylinder for a second. no road test, nothing.
Ok cool. Thanks for all the info and the link.
Turns out they aren't as hard on modifications as I thought?
I'll reinstall the clips for the lines and take it in next weekend.
