Vr 5 WRX STI front Disk Rotor
Hello all. Does anyone know about the standard spec of Vr 5 WRX STI front Disk Rotor.
Mine currently has a small crack on the disk. and now trying to find those for replacement.
I want to know if the follow disk is going to fit my car.
http://www.trademe.co.nz/Browse/Listing.aspx?id=244055138
Do I have 2pot or 4pot?? What is pot anyway?
Sorry if it's too stupid question.
Being an STI V5, you should have 4 pot front calipers, that look like this:
If so, you will need the 294mm x 24mm rotors.
"pot" is another name for the pistons in the brake calipers (which push the pads onto the rotor to enable braking) - 4 pot has 4 of these pistons (2 each side of the caliper), 2 pot has 2 :)
  • 4 weeks later...
Guest NeilWRX
As you have a V5 STI these disc rotors will not fit your car (the 277mm discs are for non STI vehicles) the size you require is 294mm x 24mm Part number DBA650
