transmission oil cooler
Ive just had a transmission rebuilt and I"m a little nervous about the flow through the radiator oil cooler.
I have given it what I would consider a pretty good flush.
Using a solvent I flushed in both reverse and forward multiple times until I could feel no improvement in flow.
When I put the first flush through with solvent it was rather restricted.
Some flakes of clutch material were caught in the pan.
With the box installed and the motor running there a noticeable pressure difference between the inlet and outlet of the trans cooler. This got me to thinking maybe thats is what blew the oil line the first time which dumped all the oil and killed the trans.
So my question is how easy should oil flow through the cooler? Maybe some pressure readings I can put a gauge on and compare to.
you do realise that pressure is the resistance to flow right? therefore, if your oil cooler flowed so much oil it didnt cool it it would be ineffective... correct? you can buy aftermarket coolers off trademe for cheep anywho
Guest itsgotgo
If it blew the line off the first time and cooked,replace the cooler.
It may seem like a pain in the ass but it will be worth it.
You may find that the obstruction in the cooler, may not come out at all.
For the sake of a few more dollars,its far cheaper than cooking another trans :)
