Check Engine Light
I have a V3 STi and the CEL Keeps going on and off.
I drive for a while then it comes on and it feels like it kind of wants to stall
I sort of coughs and splutters around in the low rev range, but when u get going over 2500rpm it is fine but the light is still on but when I am at a complete stop in Neutral it splutters a bit then runs fine and the light turns off.
Anybody know whats goin on?
Guest loren
take off the lower piece of surround under the steering wheel, by your knees when driving.
get a torch maybe. they are there somewhere.
Its the thingy on the right side of your intake manifold, little box thing with a plug on top, mine has ABC written on top of it, this happened to me and i pulled it off and gave it a good cleaning with some contact cleaner, had a build up of gunk, worked fine ever since. Hope that helps :)
Ok thanks. do u just take it off where that small box is held on by those 2 phillips screws? because I took it off by the four bolts and took that whole area away from the intake manifold and cleaned it. and when i put it back on it idles at 2000rpm nw. and runs worse than before. I also took the throttle body off and what i think is the throttle position sensor. So maybe i put that back on wrong?
