Carby HELP WANTED !
Right iv just got my 1.5l fx g carbied corolla to get aroudn in whilie i fix the r..
It runs rich at idle and has a really rough idle definatly needs a tune up
have put new plugs and distributa cap (it was stuffEd) a air filter and fuel filter tonight..It runs better at cold and worse at hot at idle so something not right..
What i need is somebody that is really good at carbs and KNOWS what they are doing ahha dont want a monkey playing with..
Carb needs a tune and the timing needs well timing cause its out..
I am going to be in hamilton for the next 3 days and if somebody on here is a bit of a wizz with these and wants a box of piss or whatever then flick me a message or alternativly does anybody know anyone in hamilton that is really good at these ie. a workshop
Brad
If it is a Jap imprt with all the emissions stuff on it then good luck
they are a bugger to get working right once they stop workin right
make sure all vacuum lines are connected and they look like they on right way round
see if it has a little window for fuel level(maybe on back of carb by firewall)
they usually have a wee pointer to tell u prper level
im like 99% sure its to do with the timing and carby settings cause somebody had a botchy as go at tuning before i bought it cause sleeperfoz had a look and reckoned timing was 180 degrees out or sometihng as it was around on the slides as far as it would go....And the carb settings were all up the wall
Guest sleeperfoz
yeah i moved the auto choke as it was on when the car was hot :)
just dialled it around untill off while the car was hot.
some one has had a real bodge go at tuning it.
sorry i couldnt do more for ya brad,i just dont have the gear :)
