De-capping Top Feed injectors.....
Has anyone had experience with de-capping GDA/GBD injectors (900cc???)
I have a set in My legacy RS, and am having a balls of a time getting it to idle now......
Have a LinkPLUS G3 and have adjuested fuel trims etc MILLIONS of times with no success......
My old setup with 650cc Sards worked sweet as.
Im after any info possible realy. Cheers
 boostin said:
Have you had them flow tested?
Not profesionally haha, Bucket/Fuel pump and timer setup......They all came out with the same reading.
Anyhow have had the Link Firmware updated and carried out function tests now. A Bosch Coil pack has a weak spark @ #1 so i'll replace that and see what happens.......
 nt_a_foz said:
Know of many people running decaped v5/6 or later and tehy work fine so should be ok if done well
Thanks mate, I found the issue i was having anyhow :)
I have done a aftermarket coil mod... and 1 of the coils has a weak spark. Hence rough running......
Cheers Again
