BC5 Rs ABS light
Hi guys,
My ABS light comes on after I start my car up, move forward, and brake for a second (not straight away) and then stays on for the rest of the time car is on, every time I drive it. Doesnt do it when reversing it, only when I go forwards...wtf? Is there a way to test for a problem it has? :-\
The ABS ECU is under the carpet under the RH side of the drivers seat.
When the ABS light has activated, don't shut the ignition off. Roll the drivers seat all the way forward. There will be a little flap of carpet to lift. This gives you access to the fault LED. Count the flashes, slow and fast. Slow are 10's, fast are 1's. 3 slow and 2 fast make fault code 32. You might need a mirror to see them.
If you can't see the pic clearly, right click and "view picture".
