Help needed
 Conrad said:
So i got the vf28 installed with the v5 ra ecu..
but now im only running 7psi boost..
could that be cause im still using my old restrictor pill?
PM Itsgotgo he's done the pretty much the same conversion you've done (although on a SF5A)
Pretty sure that's your problem though bro. Pretty sure you need a boost tap or EBC to overcome it - the restrictor pill
ok, ive given this one some thought.
I still have my v5/v6 sti ecu lying around, so while i have it i might try to figure it out.
i have used a boost tap, and that sorts out the problem, but you can hear the car detonate.
So that means the boost tap is just masking the problem, and in the meantime your still damaging the engine.
Whats the difference between a 2000/2001 forester's boost solenoid and the v5/v6 sti one?
does a foz use 2 port and the sti a 3 port? if they are different, then i might hook up a sti solenoid and that might solve it?
