EXTERNAL GATE NOT WORKING!!! HELP!!!
Guest scoobydoov3
I'm running a 38mm Tail Wastegate on my car, VF8 (currently) TD05 and all i have done is removed the vac for the internal wastegate, mine hold a sateady 15PSI through all the gears, i haven't touch the internal wastegate and it seems to holding strong
Who can make a bracket? I'm very keen to get a hold of one for the TD05, PM me if you have details
Guest Bemrose
this means in theory for are running no boost limit, and it will be very sloppy
scary too
 Bemrose']
[quote name='Bazza-NZ said:
I'm running a 38mm Tail Wastegate on my car, VF8 (currently)color=red] TD05 and all i have done is removed the vac for the internal wastegate[/color], mine hold a sateady 15PSI through all the gears, i haven't touch the internal wastegate and it seems to holding strong
scary too
no no, i took the vac hose off the internal wastegate, and now runs to the external gate, my point is that the VF8's internal wastegate doesn't blow open (well mine doesn't at lest) causing boost issues with running an external
i still have a form of boost control in there, Free boosting a VF8 would be dangerous at the moment its help 15 PSI for about 3 months, not sure how much longer the turbo will last,
not bad for a 20 buck turbo off trade me
