Handbrake not working on one side
Vehical is a 91 GTI pulsar.
The handbrake doesnt clamp down on one side. The cable is fine but the arm that it attaches to pulls almost all the way to the stopper without activating the brake and then jams in that position. I'm thinking that theres something loose inside the caliper where it connects to the piston. Has anyone had this problem and fixed it, or should i just pick up a cheap second hand one?
I know where I can salvage parts from a stripped X1r model, but I can remember if they have disc's or drums on the rear. Anyone know?
we branching out into the nissan world now :P :P
i cant help you, but sure someone can :)
my brain isnt working atm, but im sure you can also get breaks off a few of the other model nissans, just cant remember which ones.
-smurff
is it a drum or caliper? as the nissans have a caliper that does both foot and handbrake. theres a bolt it the back to adjust it and to re assemble it and you need a pair of long nose pliers to wind the piston back in...
yeah its the caliper one. I'm pretty sure i know where your talking about, The bolt comes out of the caliper and turns sqaure. The arm slips over that and a nut and spring washer keep it in place. Ive take the nut off but it seems pretty solid. I could pry the arm off but i was sorta worred about breaking it.
I'm not sure how youd go about adjusting I pulled and twisted the bolt and it did nothing.
