water pump issues
I've been having problems with my wrx cooling systems for months now. It just does not seem to be circulating water.
Initially, I thought it was the thermostat so i replaced it. No change.
Then i removed it all together. No change.
So then i assumed it must be the waterpump, so i put a new one in, no change.
I've also checked the radiator flow, and its fine.
When the car is running, even with no thermostat in it the bottom radiator hose never warms up even when it overheats and starts steaming out the overflow.
So what else could it possibly be?????
I just cant see how its even possible that water isnt circulating with no thermostat in it??????
Any help greatly apreciated as i'm about ready to take to it with a hammer!!!
I checked it with a hose. Water comes out the bottom just as quick as it goes in the top, so theres nothing wrong with it and when its in the car the top hose is hot as but the bottom hose stays cold so theres just no flow at all.
I just can't work it out eh...
well the way i see it is thats its not seriously blocked because water can flow through it without being under pressure, so at least some hot water would get through, but the bottom hose is always cold...
Where else could a cooling system block?
