engine dies
ok today after getting new plugs tried to turn it and it now ignites but..... it dies out and gives out backfires now... it also smells of petrol under the bonnet by cylinder #1 injector(top left hand side injector)
could the injector be making it die out?
or would all the oil from when the turbo went be causing it to die?
hhmmm. . . so what other problems had you had? you had a damaged turbo did you?
did you plug the AFM back in after doing the plugs
-smurff
maybe if you pop out sparkplug 1 ( were the petrol smell is ) see if the plug if full of petrol.
or even if the cylinder is. long shot, maybe the injector is leaking.
have they been taken out at all since you were able to start it last?
-smurff
haven't check codes and na they werent removed.
ill take the plugs out tomorrow and check the plug.
we were going to take the injector out today and see if there was any noticeable damages but couldn't figure out how to remove it lol
If it was running ok before, and you haven't touched the injectors or manifold then it won't be the injector.
It sounds like a massive vac leak to me. Unplug the AFM and see if it runs. Check fault codes first though. You don't want to confuse yourself with fault codes you've generated while testing things.
dont be so sure, ive mixed them up before and ive been working on them for about 6 years. look at the stickers on the loom side that show what plug goes to where. if the car went ok before u touched it (besides a the turbo oil leak?) then its obvious you havnt done something rite
the cracked plug is most likely from a rough install or removal. and make sure u have everything plugged in, correctly. if thats ok, check that its getting spark, if so its getting a cam and crank signal (all it needs to start the car), then check that its getting a fuel supply.
