Since I've been enjoying my car too much lately....radar detector install time! Its on one of those nice quick release powered mounts, NZ crowd I think? https://www.readysetradars.com/products/uniden-r7-8-mount
It works well, nice and solid over bumps and corners even with coilovers, so can recommend. install was easy...was hoping to power from cabin lights but no switched 12v there...so ran cable down to stereo and tapped into switched power for ciggy lighter since it was easier than dealing with all the fleece taped stereo harness and the supplied cable with mount is the peeerfect length.
The audio lead I added to wire into DSP since it can do auto source switching so I can get alerts through the stereo system ie interrupt audio from headunit, havent set that up yet though.
They also do an angle correction kit for the stupid angled display which makes it face flat into the car with minimal effect on detection ability, out of stock at the moment but its just a couple of screws and replaces the metal tab the detector clips onto to, so I'll grab one when they show up next.
Heading out to the garage to pull the starter in the OBXT. It makes a racket from not disengaging quickly enough when it is cold out. Did some research. Planning to not completely disassemble, but pull the case and then clean and 3-in-1 Teflon coat it.
While looking for a good video for TMIC removal, I found this for the twin turbo! Is it a lister?
The Impreza got a Gearbox and Rear diff oil change yesterday - absolutely no idea when it was last done, but the magnetic bungs did not look concerning
