boon
Admin
boon last won the day on July 11
boon had the most liked content!
1 Follower
boon's Achievements
Like a Boss
Like a Boss (7/7)
2k
  1. I had a similar experience recently. Thought my iron was faulty, biffed it and bought a flash new one, same result. Annoying to say the least, had to rework a whole bunch of s*** joins on a board afterward.
  2. f*** it just get one from Pickapart, they're like $40.
  3. Something is f***ed here, if you put a car battery across a 1 ohm load you get a good spark and a lot of heat very quickly. Unless everything involved is rather large. Suspect something is kooked with your alternator.
  4. Do you still have the motor handy? Pull the cam caps and check the journals for one that's gotten really hot. I don't think you could bend a cam on a valve, you'd just bend the s*** out of the valve or dig it into the piston crown before that happened, IMO.
  5. Chicken/egg situation: did it nip up a cam which caused the belt to snap, or is the sticking cam because the belt snapped?
  6. The BHs are super well put together cars but they feel pretty dated now whereas the BPs don't feel outdated at all. Also the BH H6 is not the same as the BP one, it only has a single exhaust port on the heads, goes reasonably well but the proper 3.0 is way better. We towed a 15ft boat around for quite a while with a BP Outback and it had no issue with it. p.s. every Hyundai we've owned, or my friends have owned, has been a complete f***ing lemon. God knows why we were silly enough to buy a second one, I guess we thought the first one being a turd was just unlucky rather than them being systemically s***. My mate thought a diesel Santa Fe would make a good cheap tow rig, and it was, right up until the gearbox gave up on life just outside of Methven on a family roadtrip around the south island.
  7. By this logic you should have to go for a cert if you take your wheels off or put new brake pads in. Which the LVVTA once actually insinuated in a particularly dented Facebook post about brake rotors needing to be certed in case you installed the wrong size ones (???). Honestly they do my f***ing head in and I hope they read this, yes without them it would be very very hard (actually I don't know, would it?) to modify cars and they provide a framework for us to do that, but some times it's completely cooked. Literally from the NZ Car Construction Manual: And it's just bulls***, over the years they've had some spectacularly useless rules that have taken years to peel back and cost modifiers thousands of dollars to comply with stupid requirements that, if someone engaged their brain for about 20 minutes, wouldn't have made it past the draft stage. When was the last time you heard of a driveshaft hoop that did f*** all on a modified JDM car with less than about 800hp? The entire organisation was built around the concept of bearded hotrodders (who are wonderful, btw) stick welding bits of car together in their shed, not the "modern" version of car modding which is basically Lego except larger, dirtier, and generally undertaken by people with lower IQs. EDIT: Apologies OP for derailing your thread. I guess the sparknotes is "be prepared for some bizarre obscure cert requirement".
  8. Standard example of one of the completely dented areas of the LVV standards. If you use all OEM parts from an identical but manual vehicle it should be a VIRM issue not a cert one. If a compatible manual ECU exists I'd go looking for one. Will make your conversion much less likely to throw a million different error codes.
  9. Was it a slushbox? Old autos sometimes do that on the dyno.
  10. At that point it's not a shift light, it's a bar-graph colour-coded tachometer.
  11. Outside of the track/strip, meh. And friends don't let friends buy monster tachos.
  12. No serious electronic work should ever be done with a soldering iron that can run off a USB port anyway.
  13. Agree that if your car's a bit ropey/on the decline it should get a 6 month recheck, not sure about some of your criteria though... I don't think my STI has had a oil change sticker on it, ever. Fundamentally this change is targeted at owners of proper classics that get loving care and driven 2000km a year, not some 80s s***box that is somehow still on the road. Unfortunately virtually all old Legacys and Imprezas fall into the latter category.
  14. Condensor (radiator) not compressor Although AliExpress probably do them too.....
  15. I can source a new one ex-Japan for about 500 USD delivered to NZ, but I think that supplier only ships to NZ. There would be hundreds of them at wreckers around the country much cheaper if you would tolerate a used one. The much trickier part would be getting one to the US without it costing an insane amount. EDIT: Actually, try Amayama: https://www.amayama.com/en/part/subaru/73210ae060 As far as I can tell they will, in fact, ship to the US. I can vouch for them, I've bought all sorts of obscure parts from them.
  • Who's Online   0 Members, 0 Anonymous, 145 Guests (See full list)
