Could anyone help me re-grease my rear shocks on my v7 sti??
They are knocking, and from reading on CS, it appears they need re-greasing.
I had subaru look at them for any loose bits/bolts etc but turned out ok,
so this is my next point of action.
I will offer some form of reward ;)
Im in Napier
thanks
Rob
 nzkaosnz said:
regrease????? if by that you mean regas, thats a suspension place jobbie. *subscribes if not*
There's a guide on here somewhere about pulling the damper out of the Bilstein and greasing up the sliding bits with cv grease which is supposed to solve the knocking issue. I should really give it a try on mine.
yeah re grease. its only the left rear shock but I would do both at the same time
 Me Old Wert said:
http://www.scoobypedia.co.uk/index.php/Knowledge/KnockingNewageRearStruts
Go here - great write up! I did the quick version this time around and used lanolin spray - did the buisso on them, I had exactly the same issues ;)
I've seen the spray on Lithium grease at Ripco for about $20 a can too if you wana use that instead of lanolin spray?
cheers mate, ur a good bugger.
was trying to find it on the net.
