spark...
Drunkenmonkey
right so the plumber and I are making a cannon out of scrap 50-80mm copper pipe and im having to sort out the ignitor.. so im thinking coil pack off my old gtb engine which has the -ve +ve and ignitor what im wondering is the ignitor just a 12V signal???
my old man built one from copper and it blew apart in his hand ::). his latest one is out of the fusiotherm green pipe and still uses a peizo ignitor. hairspray is the best propellant too. it sounds like a shotgun goin off. mean flames at night too.
The ingnitor is the earth. So power the coil off 12volts. then the neg to the ingnitor out, and then you might be able to tap the ingnitor in wire on to the negative of the battery.
I can't be sure if that will work. I know thats how the wiring gos as I do wiring all the time at work.
get a 6 volt coil then you dont need a huge car battery to power it. those torch batterys will be sweet.
 Ichi Ban']
Oxy /acet is way cool in spud guns,
my old one would fire a 60mm spud about 300m !
i like the sound of that xD we will have a car there so hence the car coil being easier,
hence having the long cable..... haha
