91 rs front mount piping kit
The GC8 ones are about the closest. One of the towing eyes needs to be cut off, a bigger hole for the piping to go down through the drivers side guard and then the pipe that meets the throttle body needs to be shortened, or fit a GC8 throttle body as they're shorter.
iv got a v5 piping kit, but unable to get pipes to go from intercooler into engine bay, as there are no areas for the pipe to fit
Is that on the drivers side? Thats where you need to cut a bigger hole to get the piping down through into the guard.
Oh yeah I also forgot, you need a plastic late model oil filler tube as the RS one sits right where the pipe goes past the battery. A shorter battery helps too, especially as the positive nearly touches the piping.
I also relieved one of the ribs in the bonnet with a hammer to stop it rubbing on the pipes.
