AFM on a 1996 legacy?
forcefed
Right, the vehicle above has injectors listed as 16611AA100.
My 94 GT EJ20H auto has greys, and also comes up as 16611AA100.
It's looking like greens are aftermarket....
i dont no what going on but it was 110% ej20r and had a orange afm..
 forcefed said:
Thanks guys, was confusing me a bit but sounds like purple will be the go,
Its not an auto anymore its been converted to manual, haha nah not bigend failure but i brought with suspected headgasket turned out to be a nice big hole blown in the side of the bore lol some1 must of been running extreme boost into it,
Yip defiantly grey injectors
Its a facelift 96
my new engine will come with airbox piping etc just need to find a purple afm now
Its probably already had an engine swap and is running the greys instead of the yellows that someone previously swapped, that would also explain it blowing up. Check to see what ecu its running before swaping afm.
 gtb36']
Applied model Model Legacy GT-B
Body Style 5-Door Estate (Second Generation, Revision C)
Engine Type EJ20R
Engine Specification 1994cc, Horizontal opposition 4-cylinder, 16-valve DOHC, Twin-Turbo (260bhp)
Transmission All-wheel drive, 4-speed automatic
Suspension
Production Period August 1997 – May 1998
Market Japan
Notes
I checked it out on the Subaru Fast catalogue system today. We can't take screen shots of it, so I snapped a pic instead.
Subaru Fast is the catalog program from Subaru. What the car actually is.
Scooby Projects is a program someone has worked out from info from the internet. Not exactly accurate.
I know which one I trust. ;)
Edit - and the same body model can be seen in the top right corner of the pic I posted.
ok far call but all i no my vin tag showed ej20r block and was a auto running green injectors and the big o AFM
ASK YOUR SELF THIS
y would i give you my old reg if i was bull shiting??
 gtb36']
ASK YOUR SELF THIS
y would i give you my old reg if i was bull s***ing??
Because you honestly believed it.
I'm not saying you're bullsh*tting, I'm just letting you know the spec your car came from factory as. No spite or malice intended.
 boostin']
ASK YOUR SELF THIS
believed it>>>no i no it and seen it ...
i just wished i had a photos of the vin tag
I ran the plate too, comes up as:
BG5-277664
BG5C5CP
EJ20H
AT trans
GTB Grade.
That's completely consistant with what i've seen before. I'm willing to bet someone put a bit of love into that car. Never heard of a turbo subie with green injectors, and as i said, Autos' come with EJ20H's. So it's probable, well, likely that someone did indeed have a play with it in japan.
