Weird electrical failure...then resurrection
matt1710
Was checking all the ICE connections into my McIntosh factory HU yesterday (and temporarily connected an identical McIntosh HU to try and isolate the error) and when I connected it all (HU, cig lighter, rear window defrost switch) up as I reassembled the dash the electrics started doing funny things - like dash lights coming on then fading away - or flashing - and warning lights coming on and not going away. As I sporadically turned the wipers on (inadvertently) they wiped very slowly - like the battery was low. The battery has been fine, is a good one and is reasonably new - maybe 2 years old. Anyway, when I got it all reassembled it wouldn't start - made a funny rapid whirring/clicking noise, but no fire. I hauled it all apart and double checked connections - all seemed ok - still the whirring/clicking. I disconnected the cig lighter/ defrost switch and HU - still the clicking. I figured I'd screwed something up, so left it overnight - battery still connected. This morning, I tried and it didn't do the clicking thing but turned over very slowly - not enough to fire. Hooked up the jumper leads and bingo - it started.
Could I have drained the battery sufficiently over the 1 hour I was playing around with the HU?? Seems unlikely doesn't it.
Haven't turned if off since jumping - so will be interesting to see if it restarts...
Did you check the battery voltage with a multimeter?
Had a similiar thing happen with our Legacy - battery was going strong and then experienced a quick and sudden death. Started fine with a new battery. Sometimes you can have little to no warning. In our case, had just driven car somewhere...parked it, listened to music for say 10-15mins and then wouldn't start. Checked battery voltage - was down to 9V and dropped lower when trying to turn over.
Weird aye!
I checked it while it was still hooked up to the other car, with both cars running - so probably not a good indication of where it was at. It was 14.4V from memory. Will check it again now - after a few minutes I disconnected the jumper leads but left the Subaru running for 30 mins or so - hopefully that was enough to recharge the battery. It started no problem after I turned it off after the 30 mins.
Voltage of battery now (engine off) : 12.92V. The negative terminal is quite crappy looking, with white stuff all around it.
Hmm - I wonder if this is connected with my sporadic 'no sound' but otherwise fully operational stereo system? I've posted re that here : http://www.clubsub.org.nz/forum/index.php/topic,13425.0.html
Someone did suggest that it could well be a speaker shorting to ground - and as it often turns on (or off) when I hit a bump with the left front wheel, they suggested looking there first. I did so the other day - the two speakers in the left front door seemed fine - and the sounds certainly didn't start when I wiggled their connections, nor even when I disconnected the speakers.
