Removing Headlight Cover
Hey, I have recently bought a 99 Legacy 250t and am wondering how to remove the headlamp lenses as they are hazy and faded.
Any thoughts on how to do this would be appreciated,
  • 3 weeks later...
 boostcut said:
polish them with jif. dont remove the lenses. they will forever leak and they will be f***ed.
Yup Jif, or a mild paint polish.
 uwa8nc']
Jif on the outside or inside of the lens?
Lol, whatever side is easier to get to.
Hint, normally the outside.
 boostin']
yeah normally the outside but, If you really want that bright light look heres what you need to do.
Remove the headlight assembly. This can easily be done by removing the grill the two side caps and the three bolts securing the enclosure. Next remove the 3 or 2 bulbs. Make sure not to touch the glass as the oil can wreck them. Once all the bulbs are removed get some bam and just spray it all through the enclosure and some water shake and bam!!! the dirt is gone. Drain the water and reverse these steps.
This will provide a extremely clear finish with no detriment to the effectiveness of your head lamps what so ever.
