how to bleed header tank
4ORGD
this for for gc8s, dunno bout earlier models, same idea though
To bleed the system, take off the small hose off the nozzle on the radiator that goes to the filler tank (there are two one is the over flow) then fill with water in the filler tank while car is running and heater is on hot setting.
Water will piss out the nozzle on the radiator when you do this but it works like a bleeder so let it piss out for a good while to let it bleed the air out ,then put the hose on again. Leave the radiator cap off... use yr finger to feel when the water gets hot-ish this means the thermostat has opened, fit the cap and it it should be sweet.
 4ORGD said:
do i leave the radiator cap off during the whole process
Yea, but only when doing from cold or warmish, obviously when its hot is a its a no go
But leaving it off helps trappaed air escape, especially when the termostat opens
Just feel with yr finger when it starts to get hot.. not REAL hot, and fit when ready
